I'm sitting at 4/6 and want to lower my rear another 1in with the 1in shackle to put it at 7in in the rear but was wondering if i would have enough clearance between my axle n the frame before i do it.
You should have clearence at 7", definitely no lower though..Chris smith is at 7" without a notch iirc and his is a nnbs rcsb
A few guys with RCSB hit tubs in the bed before the axle and frame hit..
MisreadI meant before the 275/45s
275/55s are .69" taller than 285/50s so you should be fine..may hit a littleokay so i should be good with the 285/50 then.
