HackMcMaster
Jun 26, 2012
4,758
9
Dunes
I got a roll pan coming Monday that does away with the plate, what did you guys do to relocate you plate?
Khaos
Bed Dent Club Founder
Mar 24, 2012
20,378
1,566
Albany, NY
I kept my bumper
:cheeky:
I usually see people get the one that keeps the plate. Either that or put it in their tailgate.
HackMcMaster
Jun 26, 2012
4,758
9
Dunes
Ah damn thought it flipped over as in hid away
welsh907
Rehabilitated Member
Apr 3, 2012
3,577
31
30
Anchorage, Alaska
The one cody made me is bad ass.
J_Corr
Mar 27, 2012
2,534
18
I build a slider that bolted to box and would be between box and cab behind drives side. It used a pneumatic piston which was spring loaded (normally closed). Plan was to hook up a 1/4" vavle to the ignition so when ever the vehicle was running it would pop up. Turn key off and it would drop back down. I still have the brackets and everything in a box in the basement somewhere.
HackMcMaster
Jun 26, 2012
4,758
9
Dunes
Yea this is what I wanted to do as well, just want something for now
welsh907
Apr 3, 2012
3,577
31
30
Anchorage, Alaska
HackMcMaster
Jun 26, 2012
4,758
9
Dunes
I get pulled over way too much for that to fly I at least need lights, I'm thinking I might whip up something that bolts to the inside of the tailgate with a slide connector and a quick pin
