Custom 2001 Chevrolet Silverado - Bagged, Accuair, RCSB - $8500 - Grand Prairie, TX
Status
Not open for further replies.
Adjusted
Super Moderator
3,637
25
Tacoma, Washington
$8,500 cash or money order, no lowball offers, selling to fund another project.
Regular cab, short bed
4.3 V6, ~130,000mi
2nd owner, great condition, garage kept for last 10 years
All black exterior, grey cloth interior with captains chairs and jumper seat w/ center console (not work truck interior)
Clean Texas title in hand
Located in Grand Prairie, TX. Will meet in town for test drive.
I hate to sell this, I've been the owner since 2005, but I have moved on to another project (a square body). Lots of quality work done, and quality parts installed. This truck is ready for a new, good home.
Bagged with Accuair E-Level - lays frame front and rear, never drug
Front: Firestone 2600 airbags, shocks relocated, heim tie rod ends, tubs for 24" wheels, bag cups w/ factory control arms, new upper and lower balljoints, low-profile (flush w/ frame) transmission crossmember, all brass fittings and 3/8" nylon line
Rear: Firestone 2600 airbags, QA-1 adjustable shocks, KP Components 6-link w/ panhard, 5-gallon tank, Accuair VU-4 solenoid valve unit, tubs and notch for 24" wheels, gas tank raised, cab notched for driveshaft, all brass fittings and 3/8" nylon line
Wheels: 22" unpainted black GM transport steelies
Tires: Falken Ziex 265/35/22R, fronts half worn, rears new
Stereo: (older, around 10y/o components)
Alpine single din head unit w/ ipod connection, JL Audio W1 10" subwoofers in custom carpeted box behind seats, 600w Lanzar amplifier powers subwoofers, Infinity Kappa Perfect speakers all around, JL Audio 400w amp powers speakers, some Dynamat in interior
Engine/Drivetrain:
All factory, main engine fuse box and radiator reservior relocated to accommodate for tubs, removed washer fluid reservior for clearance, cone air filter, always ran synthetic oils, 2wd.
Interior:
No damage or excessive wear (i.e rips/holes in seats, dash cracks, broken or cracked plastics), 8/10. Captains chairs with center jump seat, Accuair switchspeed controller, power windows, Denali dash surround painted black to match, escalade chrome door handles, KP Components 200psi air gauge installed in dash cubby hole, factory rubber mats
Exterior:
Black paint 7/10, all plastic/metal trim painted, complete HD 2500 front end using OEM parts, shaved tailgate and welded rollpan, Z71 valence, aftermarket chrome door pulls, power mirrors, all badges removed
Lights:
Z71 fog lights, 6k (white) HIDs in headlights, clear corner turn signals, red/clear OEM style taillights and 3rd brake light
The good:
All tubs, most metal work, air and suspension wiring done by Nfamus Suspension in Cleburne, TX. Everything loomed. Recent check up done at Nfamus in July of 2018
Everything not listed below in the 'bad' section works as designed, truck runs and drives well. Accuair air management system makes driving this bagged truck a breeze.
A/C and heat work well, all A/C components changed in 2014
Set up to lay frame on bigger wheels and tires, truck has enough lift to clear anything I have encountered during normal driving
Recently had wheels/tires balanced, oil changed, fluids topped off, checked up, etc.
Passes state inspection easily, TX registration good until 10/19
Have many receipts for modifications and repairs, vehicle history
Zero frame or body rust, all metal/frame work professionally done. Texas truck its whole life
Stereo, subwoofers, and amplifiers are all 10+ years old, but work well and sound good. Easily upgradable
Definite head turner, can drive as is and look great
The bad:
Minor transmission leak at driveshaft seal
VU-4 solenoid valve leaks air slowly - Accuair will warranty if removed and sent in
2 chips in windshield, no cracks
White gauge cluster overlay is old and bubbling, will need replacement
Bed liner peeling off
Lug nuts are factory style, no center caps - removed spikes for sale
Rattles some over bumpy surfaces
I have been honest and upfront with the condition and description of this vehicle, and therefore am firm on the price of $8,500.
** If you have a complete '99-06 5.3 or 6.0 LS based GM engine you would throw into the deal, we can discuss a lower price. If not, see notice at top of page **
If you are interested, or would like more information, please text or call me at 972-841-8732. If I do not answer please leave a voicemail.
Thanks,
Brandon
2iGjnUB.jpg 2vDXdNv.jpg 6uGbkGK.jpg 7zWN7fv.jpg aujmrDt.jpg D2MYMtd.jpg JIpHCbm.jpg
Reactions: mike.
Status
