$A_Money$81
Dec 23, 2015
12
29
ive got a 2002 silverado 5.3, a few months ago one of my horns went out i noticed it when i was locking my truck the horns blow. well i dismissed it as one horn went bad and never worried about it but a few weeks later i went to blow the horn and nothing it clicks from the relay. i take the horns off and test them there fine, i keep messing around and sometimes the horn will blow sometimes it wont. then a few weeks later im driving at night go to hit my turn signal to turn left both of them start flashing ( crazy i know). so next day i start checking bulbs all of them look fine, horn relay ive swapped it and it appears to be working. i get to thinking try the turn signals with lights off and the work fine but as soon as i hit the lights they both starting blinking instead of one side. i need help on what to check because ive run out of options, this all started back in february. any help would be greatly appriciated thanks.
marc
WhiteSilvy
May 16, 2013
5,303
123
30
canada
i am guessing you are not grounded, or shorting something out.
i would check grounds first.
i dont really know where the grounds are supposed to be on these trucks but i am sure someone else will chime in.
$A_Money$81
Dec 23, 2015
12
29
yea thats what im thinking also is a ground somewhere i mean when i hit the horn the relay clicks and the horn acts like it wants to sound but all it does is make a thud soung but when hooked to the battery it blows so it leads me to think the wiring to the horn is good
$A_Money$81
Dec 23, 2015
12
29
ive had the airbag off and looked but hell idk what im looking for inside a steering column i havent messed with steering columns much at all. i checked the wire for the horn underneath the air bag but i didnt take the steering wheel off or anything.
