Bagging a 2005 avalanche
How cheap is "relatively cheap"?
Well shockwaves are $700 a pair for non adjustable. They will be direct bolt on. Ride tech rear kit with bolt in cups and bags for Tahoe/suburban/Yukon is $300. So $1000 gets you on air. Awesome ride. Just pick your shocks and the air management set up you want and done. I sell switch speed full dual compressor kit with 5 gal tank and vu4 for $1475. So all together, $2500 will actually have all the parts necessary to be on air and be pretty much bolt on. May have just a little trimming here and there.
^ I knew that was coming.
Teaser pic until the firewall is tubbed
Minted the shocks and did the firewall tubs. So now the front fab work is finished. Just have a lot more spot welds and grinding to do then paint everything
I wish there was a 275/30r26 tire option. these 305/30 are really too wide for a 9.5" wheel.
can't really get a good picture of how much it tucks with the back still stock but put it on its own last night
this is lift at about 110 psi
