01 Sierra Build
Axle is complete and rotors/calipers are on. Have to fill the pig up with fluid tomorrow, make brake hard-lines and bleed the brakes...
Had to work late today. Put my exhaust EGR block-off plate on yesterday and unplugged the EGR, until I get a intake block-off plate.
Truck is done and aligned, but the pics are from before I aligned it. Rear end fluid started seeping out of the pinion seal after I topped it off. Thinking it is due to a little bit of powder-coat where the seal sits. I will have to take it back out and clean the seating area up in the next few days...
49.5" up front is where it is set as of now with the stock tires on. I forgot to measure the rear, but it has 6.25" Rough Country blocks on it until I get my leafs re-done. The red leafs have to be re-done in the new candy red and have the clear-coat put on them, then they will be going on.
At least it looks better than the Boyett's truck did on stockers :crazy:
Glad to see you get it mostly done!
