You want to know what size tire you can fit on your X model year truck, with what options what lift etc, post it in here.
You want to know if 285's will fit on your stock wheels, ask in here.
You want to know if 37's will fit with only minor trimming and a body lift, ask in here and then go hang yourself.
You want to know what size leveling kit you need to fit a certain size tire and/or wheel combo, ask in here.
So post up the questions! BUT try and do a lil searching and reading before you do. It might have already been said.
Use this format if you would be so kind:
Lift Specs:
Fender Measurements:
Wheel Choice:
Tire Size:
Rubbing yes/no:
Thanks!
Lift Specs:
Wheel Choice:
Tire Size:
Rubbing yes/no:
Thanks!
