Truck Dying Help
rickp1
Oct 29, 2012
8
This started a little while ago. The issue starts when I'm going down the hwy at about 65-70 and about 2000 rpm. When I punch it the truck starts to bog down, like it's not getting enough fuel. Eventually it gets worse to the point the truck dies. Sometimes the truck will start but when I press on the gas it bogs down again and I cant even get to 3000 rpm, then it dies again. After it dies I've always been able to get it started again after 10 min or so of trying. Then the truck runs fine for a while. Today it did it 4 times and I barely got home. Could this be the fuel pump failing?
I have a custom tune from Black Bear Perf. and after loading their tune the truck ran great. I sent them a data file after loading their tune and Justin told me the truck was running lean at high RMP, so on his suggestion I replaced the fuel filter. If that didn't fix the issue, he believes the fuel pump isn;t putting out enough pressure at the higher rmps and that it might need to be replaced. Based on that information, I'm thinking the fuel pump is crapping out on me. When BBP told me the truck was running lean at high rmp, I could not tell there was anything wrong with the truck, meaning it drove great. There were no symptoms whatsoever, at any speed.
Here's my other question to you guys. A couple of months back my AutoCal was popping O2 sensor errors, so I replaced all 4 of them. Shortly after doing that the AutoCal was giving me a Catalytic Converted code, which I just cleared. I came across a couple of posts stating that a Catalytic Converter can be clogged and cause these bog down issues, is that correct? Can a Cat. Converter do that??
Small update,
As I barely made it home today, the truck was dying in my driveway. It would barely rev up over 3500 to 4000 rpm. Two hours later the truck started up just fine with no issues at all. I even revved up the engine with no issues at all. COuld the issue be temperature related. Maybe this is the reason the truck starts up again after 10 minutes of trying to start the truck on the side of the road.
Thanks
R
Yes, a cat can cause similar problems. You check into your fuel pump?
Sent from an ice cream sammich.
Sounds like it could be fuel pump or injectors to me..mine was doing a similar thing a couple of weeks ago, when I would start it up in the morning it would idle for a minute or two then start bogging down and eventually choke itself out and it got to where I would be driving and it would try to die on me
Bought some carb cleaner and cleaned the throttle body real good and put some Lucas fuel injector cleaner in it and haven't had a problem since
After they truck dying in my driveway last night and not moving it, I just got in it and it drove great. I punched from a dead stop and rpms went up to almost 5500 before changing to 2nd gear and then to almost 4500 before changing to 3rd gear. So whatever the issue i think temperature is involved.
Someone is telling me that its almost for sure the Fuel Pump. I'm taking it to the dealer tomorrow regardless.
R.
Fords had fuel pump problems a couple years ago, sounds close to what my work truck was doing. When you floored it it it just bogged down. Sitting still and trying to take off was a nightmare in that pos. Had something to do with it overheating if you ran it to much under a half tank of gas.
when the truck warms up and tries to die, pop the hood and check your manifolds...if its the cant then theyre gonna be bright red...or maybe the cat will. Be careful because a clogged cat can lead to burned valves and plugs....happened to my brothers ranger, not a cheap fix
