Suspension help please...
DirtyBlackHoe
Bun B, Baracca, Beezer
Jan 24, 2011
1,009
232
Thomasville, GA
Ok so Magneride shocks are blown and I am going to delete them. I am trying to figure out which directions to go.
This is all for a 2016 Yukon Denali 2wd.
Here are choices:
1. Belltech adjustable struts up front and norcalSS rear drop. This will be around a 1/3 and deleting the Magneride.
2. Bilstein 5100 set at 1.7" and delete. I am not sure if I should crank the 5100s or leave them at zero and then run a bottom spacer?
I am good either way stance wise, altho I think lowered would look better, but would be more parts and a bigger pain to get it all right. Leveled is what I normally do, die to simplicity, but then I am going to want bigger tires on my 22s.
Main goal is to get a better ride than the blown Magneride shocks, improve stance without over doing it, and not having the wife kill me. Any help would be awesome.
Sent from my Pixel 2 XL using Tapatalk
DeanH1290
Jan 20, 2014
4,926
404
83
30
Georgetown KY
If you go with leveled, set the height using the strut instead of the spacer imo
