Im looking at one
My buddy has one of his ecsb laying frame on 22s with a little room left in it, i dont think it will lay on 4s
Metalworx has a good one also and is larger along with kp
EMW has a whole notch and bridge setup for an arm and a leg
i dont know how i feel about it sitting on top of the frame and welding it to just the top. compared to most where you weld the face on front and back of the frame. in this pic it seems like the welded more metal to the face of the frame then welded the notc to it and on top of the frame.
i dont know if it maters that the front of it doesnt use the whole frame to weld to, but its just out of the ordinary of what you usually see imo
Thats what I wondering only being welded to the side of the frame not being strong enough. For the cost of a 8 pc notch I just may go that route. Do you guys tack the notch together then weld it to the frame?
For shits & giggles I email them requesting if they can make the sides longer so that it can be welded all the way down the frame as the other side will.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
