Static NNBS (GMT-900 07-13)
On my 17s I had to run a shorter nut. I know mcg provided the shorter nuts when I purchased them. It was about half as tall as the Oem nut.
Gonna try to find the smaller nuts. But I messaged James an he said 17+ meaning 18s or bigger. I assumed I could run my 17s as long as I cut the bottom of the bolt off
I need bigger wheels asap lol. I really dont want to have to tear it all back down an put back together. Worse case scenario I can trade my sister for her ghetto ass chrome 20s that have never been cleaned
Will your tires not clear on your 17s? I don't see the problem with running them. Get shorter nuts and put the 17s on. It'll look much better low on oem 17s than ghetto 20s.
I think they'll clear. 245/70/17 I believe. Im gonna hunt tomorrow an see what I can find. All goes according to plan we'll be getting our settlement from the wreck soon an ill get new 4s
I definitely wouldn't settle for shitty wheels in the mean time. Can't wait to see it on 4s though.
Got to look at it in the daylight. Hopefully the smaller nut will work. Its not lacking much. In this pic you can see the top lugs all the way an the bottom lugs partially.
Driver side is done minus the sway bar bushings an lower ball joint bolt obviously
Passenger side is just about there. Need to put rotor, caliper on. An tightening the tie rod up
Just get shorter nuts and cut the bj bolt flush with the nut and you'll be good.
