Jared
Administrator
20,572
117
North Dallas
I finally got my rear main and oil pan gaskets leaks squared away (bad install or faulty seals, who knows) and the yank 3200 installed.
How will it be driving without the cooler installed? Should I just get the car home and then install it? Or will normal driving be fine for a bit? The shop that fixed the leaks and installed the stall did it as a favor and was going to have to charge flag for the cooler so I opted out to do it on my own next weekend. I am going out of town this weekend and wanted to know before I took the car or just leave it behind and take the daily.
*Disclaimer: I plan on installing the cooler, so don't freak out. I also do not plan on beating the car at all until so.
DV2000NJ
May 24, 2012
147
25
28
Unless you're beating the hell out of it you should be fine, a 3200 doesn't generate a ton of heat. Do you have a trans temp gauge?
11 6.2
Member
Mar 27, 2012
206
16
3200 will be fine. Helped a friend build a FBO cammed, maggied, G8 and he ran a yank 3200 with no cooler for a while
Jared
Administrator
20,572
117
North Dallas
I'm pretty sure I am going to suck it up and leave it. Just not worth the trouble if issues arise. I had that already in my mind, but I still wanted to know how I'd be around town out of traffic, I don't drive during peak traffic hours.
Jared
Administrator
20,572
117
North Dallas
I can only imagine the shit I'd have to endure if the car took a poop on the trip down there. Might as well set it on fire and walk away, and go straight to a dealer and buy a new car that day, would be way easier to swallow than listening to her.
Jake747
May 13, 2015
1,006
41
44
Seattle
Can you borrow an aeroforce or dashhawk to monitor it? It'd be really easy that way and you'd have peace of mind. But as said, a 3200 won't generate that much more heat. Is the stock cooler still hooked up?
Jared
Administrator
20,572
117
North Dallas
it runs through the radiator only. I don't know anyone that has a gauge lying around. We are leaving Friday morning. It's about a 3.5 hour trip running 75-80mph
Adjusted
Super Moderator
3,639
29
Tacoma, Washington
if youre going through austin on 35...its always peak traffic hours.
Jared
Administrator
20,572
117
North Dallas
No, not really. Didn't have a problem last few times we went down that way. I won't be in Austin during the work week.
