shocks without a sleeve
Jared
Administrator
20,572
116
North Dallas
For whatever reason, the Sensatrac shocks I got did not come with the metal sleeves, anyone foresee an issue? Both previous sets have them :uhoh:
Metal sleeve? Like a rubber boot but metal? If you're worried about the shock shaft being exposed, don't be. Never had issues with this on any vehicle/atv/snowmobile.
Belltech has note in box that says remove metal sleeve if it touches anything so I dont see a problem either...
Prolly not a big deal. Worst that could happen is rock/debris flinging up and dinging the shaft.
No no no, you all are misunderstanding what I meant, the metal sleeve that goes into the eye of the shock where the bolt goes through.
ive had sets with and without sleeves inside the bushing. as long as the bolt is snug inside the bushing, youll be fine
OO the sleeve in the bushing. The bolt will wear through that and cause a clunk at some point. You cna install for now, but it needs to be sleeved
