The 01's A/C has been out for awhile now, and between that and not running any tint it makes it day cruises kind of a beating. There is no doubt that the compressor is the issue, when the pulleys are turning I can hear that its guts came apart at some point. The work is easy, but there is a pretty wide array of compressor/clutch brands to choose from that I am having trouble with. The Delphi (OEM) comp seems to run $3-400, where as others (re-manufactured) run $2-300, I know I will need an accumulator, a new orifice, and oil - but cost on that stuff is pretty standard across every brand/store. Right now I really miss working at a GM dealership...those cheap ACD parts...
So for you guys who have replaced your compressors with a re-manufactured one - which brand/store did you buy from, what was the cost, and how long is the warranty? I would rather not go junkyard diving. Engine is a 4.3 btw. Thanks all.
