official aSSmeister build
Bruh what are you upgrading brakes for this ain't need for speed where you need to upgrade everything at the same time before you can upgrade other shit cuz how fast does this black bitch get going?
Sent in limp mode.
Sent in limp mode.
Mine made a fuego stopping from over 120 brb numbers don't go that far down assuming Mach 7
Sent in limp mode.
Lmao meant to edit not quote :eek:kay:
most people dont, but if you build up brake dust, the drilled parts can cause cracking because the heat has no where to excape when its being pushed by a pad, and the pressure and heat can cause a crack to happen. slotted atleast one end of the slot is open to atmosphere so no pressure can build.
i need breaks pretty soon. while i have it apart, i like to do it all at once :dealwithit:
i'll be going with the EBC greenstuff pads as it seems thats the popular set to go with
Some pics this week
Windshield will be replaced within a week. Will probably do 50 shield with 5 strip. Then work on finally getting the fog lights in
Bassmaster luck. Drove to work, to find out that I couldn't work, so I came home to do some shit. Tried to fish my switch out from behind the bezel, no luck, can't see it.
Did manage to tighten my loose door handle nut so that will stfu & stop rattling.
Then decided to pop the door marker lights out to paint the red to black. The can reads not to use below 60, but it's almost 70 out so I thought I'd be alright for that little piece. Cleaned, taped, cleaned, sprayed the adhesion promoter. After 2 mins it dried up all cracked. I now realize it was cooler from being in the garage..
So I quick sanded it down some and shot black for the hell of it. No good.
Sanded that back off and fuck it. The cans and in my room now to warm up and I'll try again this weekend. Till this, this dull smoke shit.
Geez that turned out to be an annoying process for such a little mod. I never mentioned painting that on forums cause I totally thought I'd get ripped a new ass lol nice to see people actually paint that thing
