Need help.
HaydenB99
Jan 14, 2014
723
11
Tennessee
So I recently had to replace a socket ( I broke the inner base while pulling out an led, I replaced it with just an $8 socket from O'Reillys, my parking lights have not worked since the day I replaced it. Well in in the process of doing the drl delete mod just figured I'd address this issue I can not figure it out, no fuses blown also have rewired and made sure it's connected numerous times
Will not come on with headlights or manually with button
Any help would be appreciated
Check the fuses again, check the relays, make sure nothing is being grounded out anywhere. Electrical issues are a pain to diagnose
Sent from pasta.
Sent from pasta.
You aren't lying man. I've tracked it down to about everything, I'm usually fairly decent with these things lol. But thanks for the input I appreciate it.
