barrrf
Apr 17, 2012
832
271
I have to replace the heads on my truck nao. I bought a set of 243 Z06 heads and am having them milled down .035". I was thinking of going with the Vinci 236 grind.
I read some stuff on cams and talked with a couple of other know it alls and I was thinking this might be the best grind for me.
2004 5.3L - I still need to be able to tow light loads and am not sure if I want to swap out torque converters quite yet.
bgray
Stylish Canadian
Mar 17, 2012
3,052
96
Onterrible, Canada
WEll without a stall its gonna be a bit counter productive
I run stage 2.5 243 heads from PRC on my lq9, and run a TSP torquer 2 231/234....i would never dare tow with it.
What kind of chassis? rcsb?ec?cc? 2wd or 4wd?
11 6.2
Member
Mar 27, 2012
206
16
Ya that cam is gonna be too much for towing IMO! I would look at something closer to the TSP 224
Nonnieselman
Mar 23, 2012
45
Get with Stock48 over on Performancetrucks.net
he can spec you a custom grind that will work great for what you need.
barrrf
Apr 17, 2012
832
271
By 236 grind I mean thats the Vinci part number - CC 4wd
Cam Specs
DUR @ .004" 272*/284*
DUR @ .050" 212* / 224*
LIFT .551 /.551
LSA 114*
Nonnieselman
Mar 23, 2012
45
Cam Specs
LIFT .551 /.551
LSA 114*
That dont sound all that bad, but thats a huge split from I/E
Im running the 215/215 .566/.566 114LSA in my stock LQ4 and it has plenty of low end and alot of mid. I tow alot and use to have a turbo, it makes good power with boost and N/A.
barrrf
Apr 17, 2012
832
271
Shit. Im an idiot. That cam is for square ports.
Trucker cam? Seems like every body runs these.
DUR @ .004" 278*/ 286*
DUR @ .050" 216*/ 224*
LIFT .551/.551
LSA 115*
Nonnieselman
Mar 23, 2012
45
8* is better than a 12* split
Ive got a 212/218 .561/.570 114 in a 5.3 in my stop.. might end up pulling it out and putting it in my 4.8 in the Samurai.
I tend to like the smaller cams since we are working with trucks here and not cars. plus if your not goin with a stall, its gonna be kinda sluggish down low.
barrrf
Apr 17, 2012
832
271
I'll probably boost this winter - blow out the bottom and rebuild from block up.
Im not trying to be unique by any means - but Im going to try to do it without buying anything brand new. A horsepower to dollar ratio experiment.
I was inspired by Hot Rod when put 28psi to a junk yard 4.8 before it detonated. They thought it was a 5.3 until they looked closer at the earl pan.
bgray
Stylish Canadian
Mar 17, 2012
3,052
96
Onterrible, Canada
I also ran a comp cams 212/218 trucker style cam in my 5.3 before in my white rcsb.
Great cam for a DD, If you are going to boost down the road alot of guys run the lingefelter cam...
11 6.2
Member
Mar 27, 2012
206
16
Ohh i completely mis understood.lol That would be a good cam N/A and prolly be decent with boost. Also the lingefelter like bgray said is alos a good cam. I believe they call it the gt2-3
barrrf
Apr 17, 2012
832
271
Pretty much what Im doing is stupid. Take a crew cab and try to make it go fast. Like tryin to make up on a fat chick to make her pretty. Close but not quite.
I figured I already have the truck. Its paid for. It needs heads. So I might as well start with what I have. Start building it up. Then get crazy with it a few years down the road - weight loss, roll cage, ect.............
move on to fgt sedan for DD.
11 6.2
Member
Mar 27, 2012
206
16
Na man not stupid at all!! One of the reasons i lifted my truck was to see thhe look on ppl's faces when I blow there doors off in a lifted truck, makes me feel all worm and fuzzy inside.lol NO homo.lol
