NBS tahoe bagged, bodied, billets
Tukn4s
Jan 24, 2011
1,856
236
Any plans on doing a HD hood/grille?
hd grille is a for sure no. there's already a large amount of people that do the HD clip swap or 03+ clip. the hood is a possibility but i think he is wanting to keep it this original clip, just colormatched. when you stand next to this thing with the factory hood it looks that much lower.
Reactions: mike. and Silver04
Tukn4s
Jan 24, 2011
1,856
236
So I wanted to dive right in on what almost no one shows you and scares everyone away from doing Tahoe's. The door latch. Theres a bunch of different ways to do this but I wanted the latch to stay as close to center on the door vertically as possible.
Sent from my SM-G965U using Tapatalk
Tukn4s
Jan 24, 2011
1,856
236
I'm assuming you had to tub the door as well, does it limit the window glass any?
Yes, I've posted pics of the door tub and the rear glass travel is more limited than stock. Three ways to prevent the stock glass from being limited is smaller wheels, no bodydrop, or way over narrowed track width. All of which are not real options.
The only real option would be go to an envoy style rear door glass.
Tukn4s
Jan 24, 2011
1,856
236
Been working on yard work and getting the shop finished up. Finally got back on the tahoe this weekend. Got the brake pedal assembly moved over, firewall tubs welded in, the new rear link bars and axle brackets.
Tukn4s
Jan 24, 2011
1,856
236
Was out of town working so haven't spent much time on the tahoe but I did spend some time yesterday getting the blower mount modified.
Did things a little differently than I have in the past. I believe this will be a quieter alternative to the metal boxes that usually get used.
The screws currently are just for holding everything together while the glue dries. I plan to remove them and seal the holes before final installation,
Baggedtwenty
May 26, 2013
15
2
3
37
Austin, TX
Yeah, I got away from forums because IG was easier but IG has just went downhill for me. I know there are a fair share of tahoes/yukons/suburbans getting bagged but the people who build them aren't active or willing to share info. So I figured id document this build on here. Bring some light back to the glory days of the forums when full builds were everywhere.
Good shit Tukn miss the days forums were rollin with post ideas, builds were great days and helpful days.
Tukn4s
Jan 24, 2011
1,856
236
Unfortunately I havent had much time to work on it lately. Was dealing with trying to get my daily back running before the cold weather hits and then left for vacation. I will be back working on it now that everything is done and I'm back home.
Tukn4s
Jan 24, 2011
1,856
236
Been spending some time working on the tahoe again now that I've taken a new position at work that keeps me from being on call as much.
Starting getting the rear tubs tacked up and did a little rework on the rack location. Installed a fbody oil pan and pick up tube on the engine so that the engine mounts and trans x member could be set.
The shorty headers that we picked couldn't have been more perfect. These headers were picked specifically for fitment.
Tukn4s
Jan 24, 2011
1,856
236
So at the end of the weekend. Some big time things got finalized.
Engine/trans
Rear tubs
Door handle linkage inside and outside
Front bumper mounts
Trans tunnel
Also added escalade roof rack and rear glass trim pieces
Reactions: BB and Dooredon26s
Tukn4s
Jan 24, 2011
1,856
236
Made some slight adjustments to where the bumper was placed and welded on the mounts. You can see the last pic for factory bumper gap
Reactions: BB
