My 95 OBS
Chris.G.Jr.
Apr 29, 2012
714
31
Bartlesville, Oklahoma
Picked it up from my old neighbor for about 4500 less then 145k miles when bought needed oil pump replaced.
151k and growing
z71
Well its mostly stock except a few things, blue led gauges, stereo system, clear glass headlights, clear turnsignals, 5% tint, removed tailgate Chevrolet strip and z71 decals
Needs a few things as of now
ac compressor-leaks
new turnsignal/cc/wiper control arm/hazard light inside flasher- hazard button doesnt work have to use force to push it down but it doesnt stay engaged and flashers flash quickly
need to install leds in hvac to match gauges
red led bulb in top brake light on shell
needs exhaust work
passenger window sometimes works sometimes doesnt-sometimes rolls up and down sometimes it wont
sometimes wipers will go crazy and not stop going back and forth after they are shut off and sometimes when they stop its in the middle of the windshield
White letters to black (screw paying for remount and balance) reason they had white letters out is bc when i got the first tire after the blowout i thought it was temporary til i got dif tires so i had them put white letters out bc the tires that were on the truck had white out.
exhaust..
what came out of the muffler.
outlet
inlet
bent tailpipe from blowout
lmao the sub mount is awesome
:lol: i thought the same thing! but it works and its only temporary til i can get a underseat box!! oh well its not like i haul people around anyways!!
Badass box mount. New pulse board will fix those wipers.
Sent from my DROIDX using Tapatalk 2
thanks! and i thought it was the board too but i took it off and didn't see any broken solders or anything, put it back in and they have worked fine its just every now and then they go crazy! may just end up saying screw it and buy a new one and if that doesn't fix it return it.
just listed the lights and signals online to sell hopefully someone who actually likes the look will bite
alright i know people will give me shit but idc.
thought id like them but idk now. maybe they will grow on me until i get dif ones. but the stock yellow haze ones had to go.
need to be aimed right.
gonna probably sell the smoked turn signals and get clear corners and clear signal lenses.
SOLD THE SHITTY LIGHTS AND SIGNALS profiting back to stock for now tile i get a little more money to buy clears,
is there any difference or better or worse thing about getting plastic housing headlights or glass housing?
found a nice set of clear glass lenses i may get then get clear signal lenses and corners.
ordered placed
crystal clear glass headlights
crystal clear turn signals and corners
Sold them ugly halo projectors and the smoked turn signals bought clear glass headlights and clear signals and corners but got sent the wrong corners awaiting arrival of new corners then ill install them to see if i like the clea corners bc imo it doesnt look to bad stock corners
151k and growing
z71
ac compressor-leaks
needs exhaust work
You need a multi-function switch. it replaces that whole winshield wiper/cc/turn signal stick (called multi-function switch)
From Rockauto.com:
1995 CHEVROLET K1500 PICKUP 5.7L V8
Electrical-Switch & Relay : Multi-Function Switch
OE PRO Part # SM219A
Base; w/ Cruise Control
WT; w/ cruise control
Cheyenne; w/ cruise control
$94.79 1 $94.79
I hope this helps!:thumbsup:
looks better than with the halo lights
thanks man i think so too!
From Rockauto.com:
$94.79 1 $94.79
thanks man that does help bc i already have to replace that bc my hazard button aint working so i dont have hazard lights which sucks ass!
