Jack1181's 08 ecsb build
Jack1181
Member
Dec 5, 2019
21
34
13
27
Wasn't planning on making one but whatever, I'm bored
2008 Silverado ecsb.. desert brown.. bought it out of family for cheap in 2016.
When I got it, it needed some work. Nothing crazy.. body was straight, had a couple dents and scratches but overall the paint was pretty much perfect. Needed a front bumper, rear bumper, tires and some other small maintenance stuff
The only picture I know of it being completely 100% stock. 2014? dem high school pic skills..
somewhere in late 16 it got tows, a toolbox?, new bumper, 2" level
toolbox didn't last long
ff a year later and got 33" wildpeaks and some other 17"s I got off facebook
cm handles
by the time winter of 17 came along truck dropped a lifter.. was on the verge of selling it but decided to go ahead and do some work to it
dod delete
tsp stage 2 212/218 low lift
beehive springs
speed engineering headers
speed engineering true duals
Reactions: sharris223
Jack1181
Member
Dec 5, 2019
21
34
13
27
how it sat Feb. 2018
clears
switchbacks
cm sharkfin and tailgate handle
also got a cm rear bumper for cheap
June 18' truck had a head gasket issue so it got tore back down
oh I also put the stock mirrors back on
Jack1181
Member
Dec 5, 2019
21
34
13
27
at this point I was pretty happy with it.. didn't do much to it and didn't drive it much
Sept 2018 got a trans cooler
got some mint tx 20"s
January 2019 truck blew a fuel line.. later found out that this happened before and my father did a half ass repair that lasted 9 years..
bed came off, new fuel pump, lines, and painted the frame
Jack1181
Member
Dec 5, 2019
21
34
13
27
after this the truck kind of sat around not getting driven much. Have a daily that I use so wasn't really using the truck a whole lot. Didn't do anything either
July 2019 wanted to change stuff up and started ordering drop parts
October 2019 finally went and got my wheels mounted on Nitto NT420v, 275/55/20
started lowering it.. truck got a whole bunch of new parts too.. new rotors, pads, hubs, belltech street performance struts/rear shocks, sway bar ends, probably more that I'm forgetting. plus painted alot of stuff up front
right after I finished
Jack1181
Member
Dec 5, 2019
21
34
13
27
December 2019 painted a set of DL3s w/ chrome caps
forgot to add in October I installed a Dynavin gm-2007 pro + a factory usb
June 2020 redid my valve covers, and coils with vht copper.
last month I replaced the bed cover, added bed rail caps
last week swapped the 1500 tailgate cap for a 2500 one
Jack1181
Member
Dec 5, 2019
21
34
13
27
also put the 1500 grill back on, I've since colormatched the bowtie, and also wrapped the impact bar. which isn't staying
that's pretty much how it sits now, I know I'm missing stuff and there's a ton of pictures the site wont let me add
Jack1181
Member
Dec 5, 2019
21
34
13
27
Since GMFS is pretty much completely dead now, gonna start updating this more:
Got tint a few weeks ago, 25 on front two, 20 over rear window.
Blew a water pump gasket the other day, so new gaskets and painted the pump black.
While I was in there I painted the tb copper. Going to pull that accessory bracket and powder it black tonight
Also bought boat so need helpers now
Jack1181
Member
Dec 5, 2019
21
34
13
27
New shift lever to replace that worn gummy old one , got a set of ck161's for $500. Dark picture but test fit to see how they look
Jack1181
Member
Dec 5, 2019
21
34
13
27
Damn, really like the direction you went.
Thanks!
as much as im not a lowered truck guy besides slammed. you have made some good choices. I would have the HD grill colormatched and installed. i am digging the new wheels.
been on and off with it. part of me wants to pull the wrap off the impact bar, then colormatch the lower valance. I'm the oddball that likes the chrome up front.
Jack1181
Member
Dec 5, 2019
21
34
13
27
So I've done a lot since I last updated this, and spent a lot of money
2003 4l80e 110k miles or so.. this came out of a wrecked 2500 single cab from my neighbors electrician fleet. Got it, tore into it and noticed it had some water in it from sitting. No big deal, this cleaned up nicely.
Case after paint:
Truetrac, 4.10s and install kit
Parts fresh out of the parts washer:
So far this is parts list for the 80e, honestly I was never expecting to go this far but everyone knows how that goes
All new gaskets, seals, bushings
Raybestos "stage 1" red frictions
Kolene Coated Steels
New bands
New pistons
Rollerize tailshaft
Rollerize front hub w/ sonnax billet
Sonnax TCC regulator valve
New Solenoids
Sonnax Trans boost valve kit
Sonnax Imidized checkballs
Sonnax regulated pressure valve
Billet input shaft?
Probably missing a few things, cant remember off the top of my head
Off and on about if I want to do HD2
I am planning on going turbo in the summer
vs 7875, kb or trick hotside, etc. motors coming out for bearings, gapped rings. Thats about it
Reactions: Huck and sharris223
Tylers88
3 GM's and a Jeep
Apr 16, 2012
6,949
494
83
Clarion, IA
Case after paint:
New bands
New pistons
Rollerize tailshaft
New Solenoids
Billet input shaft?
I want to say those are the same frictions and steels that were in the TCI kit I used in the 700 in my 88, if they are they were good
Jack1181
Member
Dec 5, 2019
21
34
13
27
Been a minute. I did ALOT to the truck but skipping the boring stuff and getting straight to the point. Sold the ck161s, added rear helper bags, re geared to 4.10s and added a trutac. Swapped out for a set of OEM clears in the front to get rid of the fog, I'm missing alot of others.
Ended up going huron v4 t4. Kit came last week, getting ready to tear the truck down and install.
vs7875, vs 44wg, 50 bov, powdercoated illusion rootbeer.
Got the intercooler mounted + relocated tru-cool
Also went down to 4/6
Reactions: Huck
