Ok. So Heres my write up on Installing e-fans on an OBS with a clutch fan.
First i drained my fluid
Now take off the shroud and get ready to remove the fan.
I used a big crescent and a rubber mallet while a ratchet strap held the fan from spinning. Took a few hits to knock it loose. Once its removed, remove the hoses on the radiator and removed the radiator.
Here is a pic with radiator and clutch fan removed
Lined up the fans and the new radiator away from the truck to test fit and size it.
I placed my new radiator in and re attached all the lines.
Once re attached i placed my LS1 fans in the lower tray and leaned the fans up against the radiator and centered them. After that i thankfully had holes already in the top of the radiator that worked out PERFECT. See below
Here you can see how/where its attached.
At this point i needed a 5/16 square drive socket/wrench to be able to remove the plug in the passenger side block where the thermometer will go for my e-fans harness.
I continued install down below.
