Help with stance
The 4/7 will be less work than a flip kit? I'm i was going to go that way and do a little at a time what should I start with and then need to add to get to 4/7? Thanks
4/7 uses a flip kit. Im saying that a flipkit will drop the rear 7" on a nnbs and to me installing a flipkit is much easier then taking off the hangers and doing shackles to get 4-5" of drop in the rear. 4/7 on a nnbs is not low enough to make speed bumps an issue unless you have monster ones for some odd reason. If you just want a nice small drop then get 1-2" coils or drop struts and do drop hangers, shackles, and remove the factory block and you'll be around a 1-2/5ish drop. Wont be much of a drop at all though. Then if your like everyone else i have seen you'll want lower then you'll need to add control arms or spindles up front and remove your hangers and shackles and then put on a flip kit. In the end its much easier to do a 4/7 and then adjust from there if you must by doing lift shackles or hangers then the front by adjusting your strut
Who has the best price on 4/7? No notching the frame right, I dont wana do that. Also if it has a leveling kit on it how will that effect the stance when I remove it? Thanks
When removed it will lower the front the amount that the leveling kit is. As far as pricing pm tim that is a vendor on here and he can get you prices on parts you want with the forum discount. He is a good person to deal with.
Notch the frame, you will be much happier. Especially if you plan on running 275/45/20. I just notched the frame and installed 1inch shackles with air shocks. Perfect setup, no bottoming out at all
