help me pick next tire n wheel set-up
which setup
  • 22x11 diesels
    Votes: 4 66.7%
  • 22x9 bigfoots
    Votes: 1 16.7%
  • 22x9 factory ltz replicas
    Votes: 1 16.7%
  • Total voters
    6
statonburrell
Jul 3, 2012
61
2
34
well, I'm gonna add an extra 1.25" to my truck via a RC BL and my tires are finally starting to wear. I feel like 20s look too small on a NNBS so I want to run 22s. Just not sure which way I want to go with it. Here's the options:
22x11 diesels on 33x12.50x22 toyot m/t
22x9 centerline bigfoot (looks just like weld dune 6) on 285/55/22 Trail grapplers (personally hate trail grapps)
images
22x9 LTZ replicas on 35x12.50x22 toyo open country m/t
the ones I posted are 22s, or do you mean you want to see 22s on a truck, I have a pic on a lowered truck, dk if tht would help you
my truck isn't THAT much higher than a leveled set-up. You guys can also recommend some other wide 22s if you want
Diesels are :puke:
Reps will need more wide :imo:
Bigfoots, Toyos and add 1" block in the back.
:fuckyeah:
Dude I wouldn't touch it, she looks sexy now :imo:
If you do change tho, you def need to go wide tho. The LTZs would look good, just not wide enough, and idk if you could clear 35s even with the x9s. I've never seen the Diesels in a 22 on a truck, but I'd def go 22x10 at least and 33x13.50
Another vote to keep it like it is :imo But out of the three I would do the bigfoots
Jonyb truck on gmfs had 22" diesels on it. I'll see if I can find a pic of it.
**edit**
Done.
Ooooooooo I forgot about Jonyb's truck. Ok, if you must, 22x11 diesels are ok. But I still say don't touch it :imo:
the 22x9 bigfoots are only +12 offset, so there would be minimal lip. I have thought about the 22x9.5 novakane 6s 0 offset but someone told me the chrome pits badly
