So I'm in the process of buying gears but not sure which to go with. I kinda have my mind set on 3 gears it's between 3.73 3.90 or 4.10 help me choose the right gears for me
Also try and estimate where you do most of your driving ( as far as RPM's are concerned) if it is mostly stop and go around town driving the 4.10's will be way more fun around town but hinder on the top end ( freeway driving, etc...) because you'll have to be turning considerably more RPM's to keep the same old cruising speed.
Gears can also help/hinder MPG's as well....The 4.10's around town might see slightly better mileage if you don't drive like an idiot because the engine has to work less to get you moving due to the mechanical advantage of the gears. The 3.73's are going to get slightly better mileage up top (freeway) but its going to take more skinny pedal to get the truck moving around town with the 3.73's....
What are your future plans for the truck? If you are looking to go the boost route I'd lean towards the 3.73's.
Give us some more info and hopefully we can help you out.
If an 80e is really going to happen then I'd look hardest at 4.10's due to its tall 1st gear.
I'd run 4.88 with this setupGood point.
I have an 80E, 4.10's, and 35's.... Let me tall ya' it is awesome for a fairly heavy truck...I could only imagine it with normal wheels/tires, possibly even on a lighter platform.
I didn't run my boost/nitrous setup for too long but 1st gear was pretty useless even with 18's & 35's, I would have favored the numerically lower gear set in that setup for sure.
I'd run 4.56 with this setupI have 4.10s in my 04 1500 and they are awesome with 33s, was a beast for dead stock on my old light 265s
So is 4.10s with 80e be good with boost & spray ?
