Off topic but anybody know how to the drl to flash with the turn signals . I have everything led even interior except for the rear brake and turn signals. I changed the stock flasher relay to a led compatible one as well. I tried to hook up the del wires to the turn signal wires but that didn't work.
You need two turn signal sockets. Solder them in line with the current ones, remove drl sockets, cap off drl wires, unplug drl fuse and you're good to go.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
