Have a weird noise going on here
garcia946
The Tint Man
Mar 8, 2013
13
Sachse/Garland
I have a weird noise coming from engine bay. Sounds like a pulley , had in in recently , they replaced the tension pulley but no dice still there. It comes and goes, every time I take it in for a check , guess what nada... Any ideas......
Quick video
Weird noise - YouTube
It sounds like a pulley, The trick i found is get a can of wd40, and spray the bearing on one pulley at a time, and see if it goes away, say you spray the idler, and the noise goes away, then its the idler pulley gone bad.
also check that your power steering is full as when the pump runs low on fluid it will make a similar noise.
