Going lower, need help with notch
Justin Greenroyd
Nov 7, 2012
713
31
Im at 5/8 now, and only going down an inch. But in the back im not notched and when all air is out of the helpers my frame is almost on my axle. I want the most clearance i can get. So what is the best mini notch to get? or are they all pretty much the same?
McG imo...
A lot of people have problems with the djm and idk if avs underbed is universal or if they make it for nnbs.
i wanna see where all these people having problems are? ive had all my djm parts in my truck for going on 6 years now and no problems. :shrug: idk if they've changed in the years since but oh well
I had problems with mine because it cracked my frame. Drilled holes in the corners of the cuts and everything. No bed on, rear leaf spring bolts out and diff down. Everything on stands and shimmed so nothing would move.
I think Jared posted a thread about it. Had multiple pictures of fucked and cracked frames from the djm notch.
yall forgetting he has a nnbs? thought there was only one company that made a bolt in notch for nnbs?
