DOT compression fitting pack
Status
Not open for further replies.
Zach.
Member
Jan 25, 2011
637
18
18
31
Bakersfield, Ca
Item is located in Bakersfield, Ca 93307
Price - $90 shipped obo
will be added tonight.
I have almost everything you need for a 3/8"npt x 1/2" tube setup. All dot except the 1/8" PTC gauge fittings.
Here's the list of the fittings
All are compression except for the gauge fittings. All are brand new but some have loctite or Teflon tape on them. They will also come with 50ft of 1/8" air line for the gauges. It's been cut into 4 sections. So each one is 12.5 ft long. This pack was put together so the valves would be mounted on the tank.
4 1/2x3/8 hex nipples
8 3/8" hex nipple
4 3/8" tee's
4 1/8" PTC male gauge PTC fittings
4 1/8" PTC female gauge PTC fittings
4 3/8" npt x 1/2" tube elbows
4 3/8" check valves
3 1/2" Elbows
2 1/2" Male Straights
1 1/4" drain fitting
You'll need fittings for your compressor, and water trap.
Female 1/8" PTC's not shown.
Status
