Colton
Mar 20, 2012
1,333
32
GM stopped doing footwell lights in NNBS trucks and I saw them in a NBS and wanted to have them. So after doing a little research and testing a few wires I found out which wire to tap into so they would dim in and out with the map lights when the doors open and close
What you will need:
2 LED strips (1 for each side) I used 6k. Strip Lights LED - 6 inch
Couple feet of 24 or 22 gauge wire
Heres what the strips look like. For the passenger side go ahead and get the extra wire you have and add them to the strip so it will be able to reach the box from the passenger side.
First, get under the dash and find this box. Its in the back left corner
Take the cover off and this is what you will see. You will be tapping into the black connector so go ahead and unplug it so you have have more room to work with
Once you have it unplugged there will be 2 grey wires in pin 8. I dont think it matters which one you use so just pick one
Then wire both lights to the grey wire. Should look something like this. Then of course wrap them good with electrical tape.
Once you have both lights hooked up to the grey wire then you will need to ground out both lights. I just found a place in the back of the footwell and used it
Now you can mount the lights. There is not very many places under there to mount them but here are the spots I used.
Drivers side
Passengers side
After you have them where you want, you will want to hide all the wires under the dash so none of them are hanging down.
Finally, plug the black connector back in and put the cover back on the box and you have footwell lights!
And here are some finished pictures:
Video of me opening and shutting the doors
http://youtu.be/aBtlOTbVMBo
bgray
Stylish Canadian
Mar 17, 2012
3,052
96
Onterrible, Canada
I have the exact same setup pretty much in my NNBS...except i put some under my rear seats too
Yes you will just need to find the Interior light wire and tap into that and make your own ground
Colton
Mar 20, 2012
1,333
32
Thanks guys. Y'all will want to do it when y'all see it next weekend, looks way better in person IMO. We do need more write ups that's why I did this. Need some more action over here!
D1nman
Mar 27, 2012
2,326
5
West Monroe, LA
Yes the nbs is pretty much the same look for the grey wire in the orange square plug under the black covered box in the divers footwell.
Colton im glad the wire finally appeared :crazy:
CUB
Jan 2, 2011
3,539
76
Shreveport, LA
Want to do this but I'll never use them. Colton's looked really crispy white in person. Very nice mod that y'all should def check out.
