Da_Rebel
Just another guy
Mar 8, 2012
183
18
Sanger, TX
Alright guys, this is my how-to for installing a DJM rear swaybar. This is a very easy install. Took me about 1 hour tops.
This install was on a 2004 Silverado 1500 crew cab. Truck has 2” drop shackles, nothing else. They do make them for lowered trucks, you just have to specify your drop when ordering so they can send the right sized end links. My contact was Tony (NORCAL SS on GMFS). His email is tony@tbssowners.com. I paid $245 shipped for mine.
Tools needed:
I would recommend using an air gun to take up all the slack in the u-bolts, they have a lot of thread. I used a regular ratchet when they would tighten up.
5/8” deep socket.
3/4” shallow socket, with hand wrench.
A little bit of grease/lube.
To make life easier, remove the spare. I had removed mine long ago, but I can tell it would have been tricky to work with if it was still there.
On to the pictures!
Picture of parts. (I’m sorry about the angle, but you get the idea)
Installed the top mounts for the endlinks on the crossbar.
Endlinks mounted to crossbar. When installing, make sure the bolt heads are towards each other.
Swaybar mounted.
Endlinks connected to swaybar. Note how the top mounts are now a lot farther apart, this was due to adjustment. Everything is still loose at this point.
Da_Rebel
Just another guy
Mar 8, 2012
183
18
Sanger, TX
Now at this point I realized the fit is very tight. Here is the driver’s side top mount from behind showing where it sits right beside the shock mount. This is the u-bolt on top of the crossmember.
Here it is again from the front, looking towards the rear.
Here is the passenger side endlink, showing how the bolt is touching the stock fitment exhaust.
Although, keep in mind, the truck is in the air. I decided to let it down, and check the fitment. Once I let it down, I gained a little bit of room.
At this point I realized something else. The swaybar was VERY close to the driver’s side shock mount on the axle. You’ll see it here. It’s not possible to correct though, because I mentioned earlier how the u-bolt for the top endlink mount was pressed up to the shock mount on the crossbar. Clearance is somewhere between 1/8” and 1/4”. It is hard to see from this angle though.
From here I began to tighten everything down, starting with the mounts for the endlinks, next swaybar mounts, finishing with the endlinks. Make sure everything is lined up so the endlinks are as vertical as possible. Everything is tight here.
To test it, I was bouncing the rear of the truck as hard as I could, and I didn’t hear anything scrape or bump. I also made a quick run around town to see if anything showed up while driving, but I didn’t see anything when I retured. That’s all there is to it. You will notice that the rear feels a whole lot stiffer making corners. I would recommend it, but be aware of how tight a fit it is.
One more shot taken of entire rear. Yes, I did chop off some exhaust and put a tip on. I didn’t need the reference point of stock exhaust anymore because of the swaybar install.
Hope you all enjoy this write up.
Colyn.
Acrophobic
Mar 17, 2012
2,223
6
Alma, GA
Really want one just wonder if a Tahoe one would work with my drop setup...
Bill
Apr 7, 2012
200
McDonough, GA
I installed one on my rcsb nnbs, made a world of a differance. Only thing was on mine was that I had to trim about an 1/8" off of the shock mount on the driverside next to the frame rail to get it to fit perfectly but other than that went together very easily with the spare tire removed.
Pics with a 6/9 drop
Khaos
Bed Dent Club Founder
Mar 24, 2012
20,378
1,566
Albany, NY
Nice write up man, this will help out a lot when I get to doing mine down the road
mrgrinch77301
Mar 24, 2012
65
Conroe TX
I need to order my sway bars now
Adjusted
Super Moderator
3,639
29
Tacoma, Washington
waaaaannnnttttt
Luis, ive gotta take a ride in it with ya sometime, trucks goin down and imma try this out - ever thought of upgrading the front one too? One thing ive heard a few times about rear swaybars is that they improve handling greatly, but only to a point; when pushed hard they will hold your ass in line throughout most of the corner but the all of the sudden just let the rear break loose, could be a shock/tire thing, but let keep us updated on that and if any of the close fits start rubbing anything.
Da_Rebel
Just another guy
Mar 8, 2012
183
18
Sanger, TX
I'll run it hard today, see if it pops loose. Will keep you updated as to how well it handles.
nvm, looked it up...
Sorry, the thread keeps changing category, didn't see it till this morning.
