Denali Tailight Moisture
nickyreno
Oct 7, 2013
1,201
Lake Tahoe, NV
I just noticed I have the infamous Denali tailight condensation issue. Is there a quick fix for this? I heard either drill a hole at the bottom, or break it open and seal it up wich are two conflicting ideas.
Find out then let me know, I have mine sitting in my closet at the moment until I decided what to do because they were having condensation bad.
From what I have read, it's the seal around the bulbs that causes the lights to do this. Not sure how accurate that is though.
Run a bead of clear silicone around all the seams, get new foam/rubber washers for the bulbs and a few of those silica packets. Put the packets in the lights and install them back on the truck. In a few days the moisture will be gone and you can remove the packets.
