Dat LBZ
IF u want just the screen order the CTS Insight. I believe I paid $300 new for it threw Danville Performance but I think Alligator has it the cheapest. It is just gauges, no tunes and if you wanted you could use the touch screen for DSP5 (LB7 and LLY only).
But I have a Q for you? What is your tire/rim setup u are running? LOVE that stance.
Thanks fellas. Been thinking about getting the 4" spindles for it. I'm cranked pretty high and it rides a little rougher then I'd like. So I may de crank back to stock and put the spindles on and run a 1 or 2" block. Should sit around 2" higher then it does now.
Front:
- decrank
- 4" spindles
-new shocks (maybe duals w hoops)
Rear:
- 4" deavers
- 2" drop shackles
Or just do a 2.5" block but I hear above has a much better ride.
Fuckers at discount put 65 psi in the tires, lowered it down some and it rides a lot better lol
Installed the lift pump and cat filter today.
eh idk. I cut open those shitty ass ebay clear headlights and robbed the lenses out of them incase i decide to clear the stockers ill have a clear lense to put back in so it doesnt look like its missing something.
