Compressor Locations...
laidbackbigun
Member
Jan 12, 2016
43
16
18
Bagging my truck over the winter, just wondering where everyone hides their compressors. Going with 2 viair 480's and please leave the "EDC FTW" stuff out of this. We know they are the bee's knees but this is about compressors. Thanks guys. Oh my plan is to still have exhaust run out the roll pan, so if anybody has ideas about that please feel free to share.
Dakota
Dat Static 4wd
Mar 12, 2012
15,997
1,041
texarkana
A lot of guys run their tanks and compressors in the spare tire area. I like the look of the compressors mounted inside the frame rails behind the axle.
A lot of it could be determined by how you plan on doing the bed floor as well. If you did a raised floor you could put the compressors under the raised section at the front of the bed and make an access door.
Tukn4s
Jan 24, 2011
1,856
268
You need to keep 2 things in mind, 1. keep the compressors from being doused in water. 2. Be cautious about the heat dissipation for the compressors. Since you still want to run exhaust all the way to the back of the truck, you need to run this first and mount the compressors and lines accordingly to keep them away from the exhaust. excess heat build up the killer of compressors. So without knowing your plans for you exhaust, that is the info I will add. If you can show the actual routing you plan to take on your exhaust, then we can make better suggestions.
yates
Stock turd
2,378
378
83
IA
I would add to put them so that if you need to change a compressor out they are fairly easily accessible.
