Changing oil pan gasket.
robstor80
Oct 6, 2014
5
Hey what's up guys. I'm needing to change the oil pan gasket on my 04 Yukon Denali. Any tips or tricks to make it easier?
Dubyagee
Dork
Jan 23, 2011
455
110
43
Oh. Its tight down there. Starter swap had me cussing
Sent from my iPad using Tapatalk Pro
dszx13
May 28, 2014
5,500
1,610
34
minden, la
If its 4wd/awd you have to pull differential out. Take off the crossmemeber under the pan. Might have to disconnect the steering linkages. I've done 1 I didn't have too. 3 I did.
Sent from my SM-J100VPP using Tapatalk
robstor80
Oct 6, 2014
5
Yeah I was looking at the pan the other day and trying to figure out if I had to drop the diff. I didn't even look at steering linkage. I can't tell if the oil pan is leaking or if the valve cover gaskets are just leaking that bad.
dszx13
May 28, 2014
5,500
1,610
34
minden, la
What year is it?
ScottyBoy
The LED Man
Apr 6, 2012
1,320
21
I just replaced the oil pan gasket on my 2001 back in March. Being that I have a 2wd, it wasn't terribly difficult. My only real obstacle was dropping the crossmember. Other than that, it was pretty straightforward.
