Well, it seems the DoD lifter plague hit my car Friday night while in San Antonio, I was able to get the car back home safely yesterday. I'm not positive, but it's most likely a failing lifter. Once I have some free time I will figure it all. Noise seems to be coming from the valve cover area, but it doesn't sound like a typical lifter noise.
That being said, I have everything ready for the most part minus cam specs
BTR 5.3/6.0/6.2 DOD/AFM Delete Kit - Brian Tooley Racing
I'm doing ARP bolts, may do the LS7 MAF. I will be ditching my jba headers for a set of longtubes, now I wish I had bought the set of kooks on Black Friday for $664 shipped! NO STALL at this time, regardless of the benefits, I just don't want to spend the extra money, the headers and tune are all ready going to cost me an arm and a leg. Pat G will be tuning the car, he has quite a bit of experience with the G8s.
Now, for cams, I am not quite sure what I will run. Looking for ideas here. The car is my DD, and will be for a while. I don't go to the track, I run heavy 20" camaro wheels. Not looking to beat up on people at local meets. I just want a very well performing cam with good street manners. Rick Crawford is doing big things with small cams. I will be checking with him, Pat G, Brian Tooley, and researching all the forums.
This one was recommended http://www.briantooleyracing.com/naturally-aspirated-ls3-stage-i-camshaft.html
Rick on a thread I read recommends 219/223
When I spoke with Pat about the BTR LS3 stage two, this was his reply: "The 225/238 113 is not a very good choice for a DD. A 13 degree split between intake and exhaust is not necessary. You lose too much low and mid rpm torque plus it takes a toll on street manners. At 5.5 degrees of overlap at .050", it's too much for a stock stall."
"If you are running stock torque converter, you want to keep your overlap at .050" less than 2 degrees. If you have a 3200 stall but are using your car as a DD, you can go up to 8 degrees of overlap at .050" before it gets too bothersome for 24/7 use."
