building a tank
Well it was riveted on my single cab so I'd assume yours is. Also have to notch back of the cab a little.
That's the big thing I was trying to a boi is cutting the cab
Cutting the cab takes all of 20 seconds, its just a lip not actually cutting into cab floor.
Technically yes, But your only notching a thin metal lip. Not cutting into the cab floor and welding a hole up etc.
Go look in the mirror if u want to see the real disgrace
Here is a novel idea, next time you want to start a thread and don't want to make yourself look like a idiot take a walk out to your truck and take a look at it so you know what your talking about. Duh it's riveted in? Duh I don't have to section the floor just cut the lip down. LOL
Feel free to :ejecto: and :gtfo: k thanks fgt
Yall are gay.
Tuk tuk, the crossmember has two rivets on each side. You can lift it an inch, and trim that inch lip from bottom of cab. If you scroll back a ways, like first pages. Youll see pics from when I did it.the first time
figures the only crossmember that wouldn't be welded in is the one i didn't look at :facepalm:
pero you haz EC on CC fgt crossmember is buried under cab
