Box and sub help
Shaddup I don't need more than that I don't think
Omfg this shit is complicated lol, I'll stick with 80a then.
you need to match or just slightly exceed the amps on the fuses at the amp to whatever you're putting at the battery. So if you have 2 40amp fuses on the amp, a 80amp under the hood will be fine. dont just randomly grab a fuse size
so in the extreme event he ran 4/0 to that tiny little amp, you'd still say to put a 400+ amp fuse?
theoretical situation here, just saying
Amp has two 40a fuses so should be perfect
Lol be helpful. Anything else I should take into consideration for the system? Anyone know where I could route the power wire through on the passenger side of NNBS?
