Important!: After wheels and tires, truck shakes when braking
Sky Mabee
May 30, 2013
18
After i put my 20x10 hostages on my truck shakes now when i brake till about 30mph. Ive heard a cause could be uneven rotors or pads but why all the sudden would it start when i changed wheels and tires? Any ideas
BOO5TED
Resident Smartass
Jan 7, 2011
20,163
11
ATL
Did the shop that mounted them balance the tires correctly? Could also be the extra weight from the new wheels/tires making the shaking worse, could have been a rotor issue before. :shrug:
Jordan
OG CGM Member
Jan 25, 2011
4,260
3
35
Old Town, ME
Take your rear wheels off and pull the metal clips off the studs if they are there. They're there for assembly, you don't need them now and they can cause vibration with aftermarket wheels.
Jordan
OG CGM Member
Jan 25, 2011
4,260
3
35
Old Town, ME
On NNBS trucks they are only on the rear, there's a retaining screw on the front instead of clips. Stock wheels have a chamfer machined into the back side that lets them sit flush unlike aftermarket wheels.
Sky Mabee
May 30, 2013
18
We'll the wheels and tires came off my buddy's truck. They drove fine and he never had the shake so maybe it's a rotor issue that is now noticeable because he extra weigh?
Also about the clips on the rear studs. I put the wheels on myself and I didn't see any clips. I wasn't looking for them of course but are they really noticeable?
Jordan
OG CGM Member
Jan 25, 2011
4,260
3
35
Old Town, ME
Sometimes they aren't immediately noticeable. There are PLENTY of other people who have forgotten to take them off before and had the exact same issue. There is 2 on either side IIRC. They'll be at the base of the stud and were used to hold your brakes together during assembly. It only takes a few minutes to pull your wheels off and check, that would be my first step going forward before throwing money at rebalances/brakes.
Sky Mabee
May 30, 2013
18
Now someone is telling me is prolly alignment problem sense I went wider. Idk imma defiantly check the rear studs
oh, i didnt realize they did that on the nnbs.
going wider will knock it out.
Sky Mabee
May 30, 2013
18
fortplainman
official CGM slut
9,398
115
35
utica ny
i know my tires are either not balanced good enough or the truck is outta alignment i get a slight vibration at 50+ but not enough to care.
