Adjustable upper ball jionts NBS
I was about to buy these because I too had too much positive camber. I had offset bushings in my UCAs (They give u more positive camber) and all I did was buy oem style bushing arms and it went away. What setup do u have right now?
I have regular bushings, I cant use offset bushings cause I'm running MMW control arms. I also have my uppers raised 1.5". So the only place I can gain adjustment now is through these adjustable BJ's. I have been considering slotting my LCA mounting holes to get some neg camber back, but I'd rather not if adjustable BJ will work.
they work, SamCarroll had them in his 4runner...theyre considered to be weaker than regular BJs but in a dropped application, I doubt that would be a problem. As long as the MMW arms use the same kind of UBJ, they will help with the camber. You should pm Tunk4s though, hes the drop guru here and on gmfs.
cool thanks bro, my UBJ's are not maxed out so strength shouldn't be a huge concern, and MMW arms use stock BJs
