Tech1451
Jun 29, 2014
8
43
Houston, TX
DemoN said above the McGughys had corrected. Is that not the case? Ordered their kit would be the easiest but if I need to piece together a kit I can.
DemoN
Mar 22, 2012
2,662
224
49
Ehhh, I am hearing people doing this. You shouldn't have to. The McG's kit is just recycled parts from the 07-13. Belltech corrected the pinon angle and centered the rear wheels by designing a new flip kit.
from what i understand from McGs is that they've replaced the flipkit and solved this issue? i haven't had any vibration issues.
those tires are huge tech1451 ....but a 3/5 should clear.
Tech1451
Jun 29, 2014
8
43
Houston, TX
Thanks. I've pretty much narrowed it down to the 34170 kit if they've corrected the issue. Hopefully I won't have to shorten the drive shaft and the alignment come in ok.
I was going to start at 3/5" and hope that clears the tires. Then when it comes time for tires I'll probably go lower.
If anyone else have installed this kit please feel free to chime in.
Trey15
Aug 3, 2014
3
Gonzales, LA
I want to do a 3/5 on my 14 sierra but looking at pics seems like it will not be level with the front so should I go 3/6 ?
TheSuspensionSource
The Lowering Experts
Here is a 2/4 on a reg cab
DemoN
Mar 22, 2012
2,662
224
49
Having the correct flip kit should get you the look in that photo. He is using just the straight 7" flip kit. Part number 6526
so the rear on mine looks right to you with the McG's 6" drop? that's something at least lol i could add 1" drop shackles in the future then.
