Anttras
Jul 19, 2013
2
So ive been having this problem for a couple years already. When I make turns, especially when going up driveways or entrances to shopping malls and stuff, I hear a pooping noise coming from the left wheel area. Ive replaced the tie rods thinking that was the problem and the noise went away for about 3 days then came right back. Havent done any other work to the suspension. Any ideas?
ok heres my ideas, as always start with cheapest first.
Check that the tire isnt rubbing the fender lining as well as the A arm.
If it is, just trim the liner, or crank the Torsion bars for more clearance.
Secondly, (only if 4x4) make sure that the CV shaft isnt binding up causing the poping noise.
thirdly, depending on how bad the noise is, some people confuse intermediate shaft clunking for poping noise,
If its 2wd, the Rack and pinion may be getting some play, you can sometimes get a little more lift out of playing with the adjuster for the lash, just dont go to far.
When you replaced the tie rods, did you do inners and outters? 2wd need not apply here.
Anttras
Jul 19, 2013
2
Its a 2wd extended cab.
Im pretty sure that the tire isnt rubbing
I replaced inner and outter tie rods.
Its a definite popping noise, just as you think a poppin noise would sound, I dont know how else to explain it further hahaha.
So I guess that leaves the rack and pinion?
Cleanoh4
Aug 27, 2013
4,346
184
40
NJ
Body mount insulator?
#06-08-61-003D: Underbody Pop or Clunk Type Noise While Turning or Driving on Uneven Road Surfaces (Install Body Mount Insulator) - (Sep 10, 2008)
Subject: Underbody Pop or Clunk Type Noise While Turning or Driving on Uneven Road Surfaces (Install Body Mount Insulator)
Models: 2004-2008 Cadillac Escalade, Escalade ESV, Escalade EXT
2004-2008 Chevrolet Avalanche, Suburban, Tahoe
2004-2008 Chevrolet Silverado (Classic), Silverado
2004-2008 GMC Yukon, Yukon XL, Yukon Denali, Yukon Denali XL
2004-2008 GMC Sierra (Classic), Sierra Denali (Classic), Sierra, Sierra Denali
This bulletin is being revised to update the model years and include diagnosis information. Warranty information has also been updated. Please discard Corporate Bulletin Number 06-08-61-003C (Section 08 - Body and Accessories).
Condition
Some customers may comment on a pop or clunk type noise while turning or driving on uneven road surfaces. This noise can be heard and/or felt at either the driver's or front passenger floor pan area.
Cause
Under certain conditions, normal movement between the frame and the #1, #2 or #3 body mounts may cause this noise to occur.
Diagnosis
1. If the vehicle is equipped with aftermarket (non-GM Accessory) running boards or the running board is mounted using the body mount bolt, remove the running boards prior to test driving the vehicle. This will eliminate the running boards as the possible cause of the noise.
2. Install the J-39570 Chassis Ears to the frame rail at or near the body mounts.
3. Test drive the vehicle to identify which mount is suspect.
Correction
Install an insulator at the suspect mount(s). The insulator should be installed between the upper portion of the body mount and the frame bracket. The #1 mount is the mount located just under the A-pillar. The #2 mount is the mount located just under the B-pillar. The #3 mount is the mount located just under the C-pillar. Use the procedure listed below.
INSULATOR PART NUMBER 15899719
1. Raise the vehicle on the hoist. It is recommended to use a four-post lift or strap the vehicle frame to the hoist arms.
2. For the left side mounts only, remove the intermediate park brake cable. Perform the following steps:
2.1. Remove the nut from the park brake equalizer.
2.2. Remove the intermediate cable from the equalizer.
2.3. Depress the retaining tabs that secure the park brake cable to the frame.
2.4. Pull slightly on the cable from the mounting area in order to provide slack for body movement without binding the cable.
3. Remove all of the body mount bolts on the side being repaired.
4. Properly support the body at the body mount area.
Caution: When you remove the body mount, do NOT separate the frame from the body more than is necessary. Possible personal injury and damage to multiple parts may result.
5. Lower the chassis accordingly in order to remove the upper portion of the body mount.
6. Install the new insulator to the bottom of the top portion of the body mount. The picture shows the insulator (1) location after the body mount is reassembled.
7. Install the body mount to the frame bracket.
8. Perform the following procedure before installing the bolts.
8.1. Clean the bolt threads of all the original thread locking compound.
8.2. Clean the threads of the bolt with denatured alcohol or equivalent and allow to dry.
8.3. Apply Threadlocker, GM P/N 89021297 (In Canada, use P/N 10953488).
9. Install the body mount bolts.
Tighten
For 2003, 2004 and 2005 model year, tighten the bolts to 85 N·m (63 lb ft).
Tighten
For 2006-2008 model year, tighten the bolts to 100 N·m (74 lb ft).
10. Reinstall the intermediate park brake cable (left side only).
