2004 Silverado Prerunner Build
TheBrettster
Administrator
Dec 9, 2010
2,705
238
Replace all the o2 sensors today, did notice the actual drops of oil on the ground are coming from the boot on the rack and pinion. For some reason I though the pitman arm was bad because the steering on the truck is SUPER loose and feels like your driving a boat. I'm gonna go ahead and order a new one today. There is def a trans line coming out of the rad that has signs of leakage but doesn't look too bad.
Reactions: barrrf
TheBrettster
Administrator
Dec 9, 2010
2,705
238
Tuned it up and swapped out the rack and pinion which was causing the second leak and the truck to handle all over the place. Decided to check compression while swapping out all the plugs. Everything was between 1-3 PSI, hard to see on the gauge but between 167-170 PSI so the bottom end looks good. The lower trans line was leaking and spraying on the front of the block, i cut a replacement line and connected it to the old one by the pulley for now. When i rip the trans out I will end up swapping them both for new lines but for now this should work.
Reactions: SamCarroll
TheBrettster
Administrator
Dec 9, 2010
2,705
238
We can be romp buddies when my FOXs get here
Come down for the build! When the kit comes I'm pretty sure I can bang it out in a day or so. I found a mobile welder/fab guy so the welding is sorted.
Reactions: BigBoi
TheBrettster
Administrator
Dec 9, 2010
2,705
238
Installed the LT's, lucky day, found 10$ in lowes parking lot and all the bolts came out and not one snapped. I did start presoaking the bolts last monday, twice a day, with Seafoam DC
Khaos
Bed Dent Club Founder
Mar 24, 2012
20,378
1,564
29
Albany, NY
I would hope after soaking them for that long that they would come out without issue. I just did mine for a day before and I got lucky. Glad to hear that went off without a hitch.
Huck
GSU Eagle
Jan 27, 2011
12,264
1,354
Gainesville, Ga
That’s a good idea, soaking them that long. I soaked mine on my red truck before I did headers for 2 days and still snapped 2
TheBrettster
Administrator
Dec 9, 2010
2,705
238
Good thing i returned the Aero AT3030 for the 3030XL. Exhaust is stupid loud with the tubes. Still awaiting on black bear for the tune and FLT for the trans.
Reactions: Dirtmafia
TheBrettster
Administrator
Dec 9, 2010
2,705
238
Iinstallation looks stupid simple since the shock box just slides right between the OEM UCA mounts. Think the hardest part is lopping off the stock coil spring mount.
TheBrettster
Administrator
Dec 9, 2010
2,705
238
Not yet,
Waiting on selling one of my rental homes which closes the end of September. Plus its too fucking hot outside TBH.
