Sup yall, haven't been on here in a minute. Been busy with work/school/life. Putting the truck up for sale as it's not practical for me at the moment. I drive 100 miles round trip to work, so I'm looking at buying a car. Most of you know the truck, check my build thread or PM me for more info. Truck currently has 164k and will go up.
PERFORMANCE
AFE Intake
PPE Boost Valve
Magnaflow 5''
ProFab Air Horn
MBRP downpipe
LML driver side exhaust manifold
FASS Titanium lift pump
70hp EFI Live tune
INTERIOR
Weathertechs
Cubby in place of air bag switch
Jensen Indash
Rockford Fosgate speakers front and rear
MagLite Mount on overhead console
PPE Boost gauge
Steering column pod
LEDs
GM rocker guards
EXTERIOR
Morimoto 6000k HIDs
5% tint, 35% windshield
CM handles, mirror caps, bumpers, grille
Billet bowtie/grille
Rigid Pods in rear bumper
SwingCase toolbox
Truxedo LowPro tonneau cover
Truxedo stake pocket covers
Fender liners
NNBS 2500HD badges
LED third brake light
Spyder LED taillights
Recon NNBS cab lights
VLEDs 5K switch backs
Double blinker mod
Clear corners
Escalade antenna delete
MBRP 6" double wall tip
Stock 16s
New 305/70r16 Cooper STT
Bed is an 07 and rust free
SUSPENSION
Stock keys cranked
Bilstein 5100s front and rear
Z71 bump stops
Tie rod sleeves
MAINTENANCE/NEW PARTS
Injectors replaced @ 138k w/ Bosch
Moog pitman/idler arm/bracket
OEM waterpump
Fuel level sensor
Timken front passenger hub
New rear left caliper
New rear pads and rotors (Powerstop)
New hard brake lines (OEM Teflon coated)
Idler pullies/serpentine belt
Transynd trans fluid, Allison filter
Minor issues that I'll make known- Couple door dings, rockers/cab corners are starting to rust, a few scratches, rock chips, driver seat is starting to tear but isn't all the way through, doesn't have a hitch of any kind, (was rear ended and it was bent and I haven't replaced, no the frame is not bent), rock chip low passenger side of windshield (hasn't gotten any bigger in the past year), needs front pads and rotors which I'm installing this weekend.
Build thread- http://customgm.com/under-construction/7937-fiestys-2002-lb7.html
I'm sure I'm forgetting stuff. I threw it on craigslist for $16k. I'll sell it to a forum member for $14.5k if you promise to take care of it lol
Any questions just comment or PM me.
PERFORMANCE
AFE Intake
PPE Boost Valve
Magnaflow 5''
ProFab Air Horn
MBRP downpipe
70hp EFI Live tune
INTERIOR
Weathertechs
Jensen Indash
PPE Boost gauge
Steering column pod
LEDs
GM rocker guards
EXTERIOR
Morimoto 6000k HIDs
SwingCase toolbox
Fender liners
NNBS 2500HD badges
Double blinker mod
Clear corners
Stock 16s
SUSPENSION
Stock keys cranked
Z71 bump stops
Tie rod sleeves
OEM waterpump
Fuel level sensor
