1clean99
switch newbie
Jan 5, 2011
169
16
So I finally began tearing the truck apart so I can redo my air management with accuair. Everything worked fine except for a particular valve sticking occasionally. Also picked up a welder so I can actually do some things myself lol.
My to do list
Install vu4
Install switch speed controller
Rerun lines to 3/8 (currently 1/2)
Replace all fittings
All digital gauges
Install front shocks
After getting the bed off I was pleased to see everything still looked good since it was installed in 2011.
Anyways onto the pics
Bed removed
Removed valve manifold
Wires cleaned up a bit.
I am thinkin if mounting the vu4 and switch ecu right where the old manifold was between the tanks and compressors
Trevor F
Member
Mar 8, 2011
210
16
Sweet. The accuair setup should help clean it up even more. Looks a lot like how I had mine setup on my first nbs.
1clean99
switch newbie
Jan 5, 2011
169
16
I plan on doing that first. Gotta get a pressure washer from my friend
Tukn4s
Jan 24, 2011
1,856
268
i was wondering the same thing...
damnit lol.
How do you have your Vu4 mounted brett?
just waterjet myself a plate for the Vu4 and mounted it under the bed off my air tank crossmember I made. I have no pictures. Its extremely easy for me to get to because I have a low profile jack that can get under the truck laid out to my very back crossmember.
I'm run one 5 gallon tank on my truck. I hardly ever mess with my truck, so I have no need for any more.
