Tukn4s
Jan 24, 2011
1,856
266
Started the next build today with the intimidator being completed last week. Just got the truck opened up to get it ready to be cut on
Build info
07C 4.8l ccsb Silverado
Bagged on 26's
Using unparalleled customs front kit
Nfamus 3 link
York 210 EDC
Two 8 gallon tanks
2 piece driveshaft
Relay box and computer relocated into cab.
TwistedWrangler
Feb 24, 2016
246
44
28
Terrible Haute, IN
It's going to hurt watching this. My dream, a truck identical to mine, but not mine. At least I'll have a clear vision of a possible future!
bagged00
Mar 21, 2012
1,096
25
34
Goong to watch the fuck outts this thread. Cant wait to see your sork on this one.
Tukn4s
Jan 24, 2011
1,856
266
I will try to keep this thread pretty detailed as far as anything I have to do to get it laying flat. It's far too often I see crewcabs and they don't lay flat. the front is almost always higher. Not sure if it's people over notching the rear or just not getting the front down.
bagged00
Mar 21, 2012
1,096
25
34
While were on the notch topic. How deep for the notch and i looking to lay a 275 30 24. I know a 265 35 22 was like 2"
Tukn4s
Jan 24, 2011
1,856
266
I like to run nice size bumpstops on vehicles I build. 275/30r24 is only ~1.25" bigger than a 265/35r22. I removed the factory bumpstop mounts and bump stocks from the SS I just did and Used them on the bottom of the notch for it and it was perfect. It was with a 10" notch. If you don't want that much you definitely don't have to have it that large. He wanted the big notch cover and tubs though.
bagged00
Mar 21, 2012
1,096
25
34
Yea im not into all that big notch shit. Im trying to keep my bed as functional as possible. Probably going to cut the factory bumpstop to the first bellow and over notch that much. I plan on raising the bed floor and hopefully the bed will still be slightly functional
Moore
Feb 12, 2012
1,136
227
29
Maryland
When you're relocating these fuse boxes and what not are you like..cutting each wire and extending them? Or pulling out from loom and just moving?
Tukn4s
Jan 24, 2011
1,856
266
you only have to extend the wires for your ABS sensors, Brake Reservoir sensor, wiper motor, headlight, turn signal and fogs, and Efans (if equipped). the engine harness and interior harness can be left alone.
Moore
Feb 12, 2012
1,136
227
29
Maryland
I always wondered how miserable it was to do, I figured it was just moving them out the way for the large majority of it. :shake:
Tukn4s
Jan 24, 2011
1,856
266
if you leave it in the engine bay you only have to extend the main power wire from the battery to the relay box and possibly the RVC Plug on the negative ground wire depending on where you locate the battery in reference to the Relay box.
Tukn4s
Jan 24, 2011
1,856
266
Well boys, the plans for the truck have changed. The truck will no longer be on 26's. the truck will be getting the 24" sweeps I used to have. the tires will be 285/35r24 front and 295/35r24 rears.
Dakota
Dat Static 4wd
Mar 12, 2012
15,996
1,041
texarkana
Niice. 26s would have been nice to see but can't go wrong with the sweeps.
