06 chevy silverado 2500hd 6.0
dustylong54
Jul 2, 2014
4
plus.google.com
Hey on my chevy I put I 6" rough country lift on my truck with 37" and went to tow with it and it really sucked at towing I got told to change the diff gears and was thinking about put a straight alxe in I can do all the work myself but does anyone know about how much I would have in it and wherr to get the kit from?
tanner
Oct 9, 2013
24
You'll still need gears in the rear end to get some power back if you put an axle under the front
Khaos
Bed Dent Club Founder
Mar 24, 2012
20,378
1,566
Albany, NY
4.56 minimum in order for it to not be a complete dog while towing. I'd go 4.88 or 5.13 personally.
Huck
BIIIIG SQRBDY GUY
Jan 27, 2011
12,338
1,389
Gainesville, Ga
^What Chris said. You'll need to regear front and rear regardless. For a gasser, general rule of thumb is 4.56 for 35s and 4.88 for 37s to get back to stock feel. 4.88/35s or 5.13/37s for a little extra power/get up and go but a couple hundred more rpms on the highway. That and a good tune from Black Bear Performance would go a long way without all the trouble of a SAS.
I'm sure someone on here can chime in, but I would check out Pirate4x4 for all the details of a SAS for your truck. It's pretty damn involved and your truck will be down for a decent amount of time for that, even if a shop does it. There's no "kit" for a solid axle swap, but places like Off Road Direct can point you in the right direction. You basically have to piece it together tho, from springs, brackets, steering, transfer case, driveshafts, sensors, brakes, etc etc. As I said, there's quite a bit involved
dszx13
May 28, 2014
5,500
1,610
34
minden, la
This may help
