Tukn4s
Jan 24, 2011
1,856
268
The Avalanche is back to be redone. The truck has been on the road for the last 2 1/2 years since it was first bagged and the owner has decided he wants more out of the truck.
The truck is going to be bodydropped over an entire new chassis. I will be using an 03 coil spring truck front clip to get better geometry and rack steering and building a 3/4 frame for the truck.
I'm using CAD to do a majority of the design work on the redo for the truck.
Built the rails and set them aside. Going this weekend to get the 03 frame and will get it situated and ready to tie into it hopefully next week.
mike.
Jan 29, 2011
8,941
1,024
North Mississippi
This is gonna be sick. Shocked as fuck your crew cab is still stock. Lol.
Tukn4s
Jan 24, 2011
1,856
268
Have no time to do anything to it which I prefer. Just be building other people's stuff. Cheaper on me
Tukn4s
Jan 24, 2011
1,856
268
Picked up the coil spring frame clip this weekend. Guy gave me everything attached. So I got everything removed and about to cut it down to mate it with the new rails this week.
Dakota
Dat Static 4wd
Mar 12, 2012
15,996
1,041
texarkana
Niice! Is there an expected completion date or just kinda whenever yall are happy with it?
Dakota
Dat Static 4wd
Mar 12, 2012
15,996
1,041
texarkana
Im going to try to have a rolling chassis LST. Doubtful to be rolling under its own power
Niice! I'm gonna try to make it to lst this year so hopefully I can check it out.
Tukn4s
Jan 24, 2011
1,856
268
Frame table, nahh I have a concrete slab and some jack stands.
This is how we build a lot of our equipment too. Looks good for completely starting over from scratch.
I had a jig setup for keeping everything straight. While I was welding it. After it's all said and done I'll take it to have the frame trued. You are correct though. I do not have a frame table.
