chevy53martin
Jan 12, 2014
Rough county is only 4 inch I can find .. Is it bad on the truck? I don't wanna have to replace a bunch of front end parts a year later bc of it
Huck
BIIIIG SQRBDY GUY
Jan 27, 2011
12,335
1,389
Gainesville, Ga
Agreed with Kyle. The only difference in their 4 and 6 kit is you get their keys to crank the front higher and either a bigger block or an AAL in the rear to get it to 6. Go ahead and buy the 6" and just don't crank it high. You can crank a little more than the 4" and still ride ok/have good angles
chevy53martin
Jan 12, 2014
But won't it sag bad in the front if I do that bc the block for the rear is a 6.25 inch
chevy53martin
Jan 12, 2014
The rough country doesn't come with keys in either lift . It's just a bigger block
chevy53martin
Jan 12, 2014
Is a 4 inch susp lift bigger than 3 inch body ? Bc someone told me that 3 in body lifts look bigger than 4 inch suspens
CammedVmax
Still stuck
Jun 5, 2013
5,042
36
Longview, TX
Do 6" and decrank it, and run smaller block in the rear. Then your angles won't be shitty and you can always go higher cause everybody does eventually.
Andrew.
:hnnng:
Jan 20, 2011
649
Canadadia
4" lift.
pros - flat angles. cheap. easy to install.
cons - you'll want to go higher as soon as you putt he wheels back on.
Tylers88
3 GM's and a Jeep
Apr 16, 2012
6,949
494
83
Clarion, IA
Dont even need smaller block IIRC since RCX 6" is block and add a leaf just leave AAL out
