tire help....
madmann26
Sep 22, 2014
41
Lilburn, Georgia
So, I'm pretty much limited to using stock 17in GMC wheels for the time being.
With that being said, up front I have 7.5in, P27 code wheels. Out back is 9.5in (had them widened by Weldcraft).
I have 275/60's on all 4 corners.
The problem is that the sidewalls on the rear are "beefier" than the sidewalls on the front. I know I'm looking at changing the front tires out but what size do I go with to get the similar look?
Thanks in advance,
hard to tell from the pic but doesnt look much different to me, if anything the fronts are beefier. If you are still looking to stay at the same tire height (around 31") then youll just have to get a wider tire.
Adjusted -
It's hard to explain but the front tires seem to sit "flatter" at the bottom of the tire vs the nice round look the rears have.
I'll post more pics of what I am talking about but it will be a few days since it's still at the collision center getting fixed from a Dec 4th accident where someone rear ended me. :down:
