TILLERS 2K16 Silverado build
Rcsb shouldn't. Ec an cc on nnbs are heavy in the rear so they do. Curious about the newer trucks. Yalls roads are nice tho. Lol.
Finished up completly. Got hitch but back on, on the 14 and up if you don't put the bolts in the side where the hitch mounts you will have a floppy bumper due to bumper bracket using the same hardware as hitch to mount. Also got it aligned everything was in spec except caster which was like -5* off any ideas on how to fix this?
Did you have offset uca bushings? Or the 1 degree cam plates?
No, I didn't get any. The truck doesn't have the regular cast uca and lcas they're like a stamped steel. I have to order different spindles because they're not the cast type
got around to removing the badges and bow tie from the tail gate today
FUCK, how much rake did you have stock!? I'm sitting at 2/4, and no way another inch in the rear would have me sitting as level as you. I'm looking at probably a 2/6 or 2/7 to sit level, it's ridiculous lmao
Would you mind posting up a rear ground to wheel well measurement? I'm curious if I'm actually 3" taller than you in the rear or not.
32.5 on the drivers side and 33 on the passengers side
The rake was retarded
Told my wife i won't get a new truck. These new Rcsb look bad af.
